HP Chromebook 11A G8 EE Bezel Replacement
Inleiding
Ga naar stap 1This guide is a prerequisite guide that will show you how to remove the bezel in the HP Chromebook 11A G8 EE laptop. On the laptop, the bezel is the black border that surrounds the screen. Bezels protect the screen and wiring from becoming damaged, and adds structural integrity to the device.
Wat je nodig hebt
On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
Één andere persoon heeft deze handleiding voltooid.
