HP Chromebook 11-v011dx Key Board Replacement
Inleiding
Ga naar stap 1The keyboard can become damaged or stop working over time. This guide will show you how to remove the keyboard.
Wat je nodig hebt
Gereedschap
Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
Lift up the black rubber cap until it is completely removed.
Repeat this until all four of the black rubber caps are removed.
Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
Lift up the small black rubber cap until it is completely off.
Repeat this step one more time to remove the other small black rubber cap on the other side.
