Ga door naar hoofdinhoud
HP Chromebook 11 G8 EE Motherboard Replacement
Philip Pedersen
Philip Pedersen en 3 andere bijdragers
Voor het laatst geüpdatet op May 7, 2024
45 minuten
Gemiddeld
The motherboard is the primary piece of circuitry that helps keep your laptop running. After troubleshooting through the possible issues with the motherboard and determining that it needs a replacement, you can follow these steps in order to accomplish that goal. This guide will walk you through the steps of replacing the motherboard in your HP Chromebook 11 G8 EE.
Note that there are many symptoms to a failing motherboard such as a loose connection that is a lot less costly than a replacement.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. HP Chromebook 11 G8 EE Motherboard Replacement, Keyboard & Touchpad Assembly: stap 1, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Motherboard Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11 G8 EE Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Motherboard Replacement: stap 3, afbeelding 1 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 3, afbeelding 2 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Motherboard Replacement, Speaker: stap 4, afbeelding 1 van 2 HP Chromebook 11 G8 EE Motherboard Replacement, Speaker: stap 4, afbeelding 2 van 2
    • Peel back the film over the speaker's motherboard connector.
    • Disconnect the speaker cable from the connector on the motherboard.
  5. HP Chromebook 11 G8 EE Motherboard Replacement: stap 5, afbeelding 1 van 2 HP Chromebook 11 G8 EE Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Unseat the speaker cable from the routing channel of the battery.
  6. HP Chromebook 11 G8 EE Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 3.5 mm screws from the base enclosure with a Phillips #1 screwdriver.
  7. HP Chromebook 11 G8 EE Motherboard Replacement: stap 7, afbeelding 1 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 7, afbeelding 2 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Lift the speakers off the base alignment pins to remove.
  8. HP Chromebook 11 G8 EE Motherboard Replacement, Battery: stap 8, afbeelding 1 van 1
    • Do not puncture or damage any parts of the battery.
    • Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
    • The speakers are removed in these images, but they don't need to be to replace the battery.
  9. HP Chromebook 11 G8 EE Motherboard Replacement: stap 9, afbeelding 1 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 9, afbeelding 2 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Remove the four 3.5 mm Phillips #1 screws securing the battery.
    • If you've already removed the speakers, you'll only need to remove the two screws on the top of the battery, near the motherboard.
  10. HP Chromebook 11 G8 EE Motherboard Replacement: stap 10, afbeelding 1 van 2 HP Chromebook 11 G8 EE Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Carefully lift the battery up and out.
  11. HP Chromebook 11 G8 EE Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 3 HP Chromebook 11 G8 EE Motherboard Replacement, Motherboard: stap 11, afbeelding 2 van 3 HP Chromebook 11 G8 EE Motherboard Replacement, Motherboard: stap 11, afbeelding 3 van 3
    • Unscrew the single screw securing the Wi-Fi card/cover using a Phillips #1 screwdriver.
    • Remove wireless antenna cables from the module using tweezers.
    • Pull the Wi-Fi card out from its motherboard port using tweezers.
  12. HP Chromebook 11 G8 EE Motherboard Replacement: stap 12, afbeelding 1 van 2 HP Chromebook 11 G8 EE Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the webcam cable from the motherboard using tweezers.
  13. HP Chromebook 11 G8 EE Motherboard Replacement: stap 13, afbeelding 1 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 13, afbeelding 2 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Flip the two black lock bars on the ZIF connectors using tweezers.
    • Disconnect both ribbon cables from the motherboard using the tweezers.
  14. HP Chromebook 11 G8 EE Motherboard Replacement: stap 14, afbeelding 1 van 2 HP Chromebook 11 G8 EE Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Disconnect the power cable from the I/O board using tweezers.
  15. HP Chromebook 11 G8 EE Motherboard Replacement: stap 15, afbeelding 1 van 2 HP Chromebook 11 G8 EE Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Peel back the film and lift the lock bar on the display panel cable with tweezers.
    • Disconnect the display panel connector with tweezers.
  16. HP Chromebook 11 G8 EE Motherboard Replacement: stap 16, afbeelding 1 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 16, afbeelding 2 van 3 HP Chromebook 11 G8 EE Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Remove the six 3.5 mm screws with a Phillips #1 screwdriver.
    • Lift the USB-C bracket off the motherboard.
  17. HP Chromebook 11 G8 EE Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Lift the motherboard up and out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Philip Pedersen
228 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Lid van UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 55
Altijd: 1,008
