Ga door naar hoofdinhoud
Google Pixel 5 Screen Adhesive Installation
Wat je nodig hebt
    1. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: stap 1, afbeelding 1 van 3 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: stap 1, afbeelding 2 van 3 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: stap 1, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Peel off as much adhesive as you can with a pair of tweezers.
      • Use a spudger to scrape away any lingering adhesive.
      • Don't use metal tools to scrape away adhesive as this will damage the frame.
      • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: stap 2, afbeelding 1 van 3 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: stap 2, afbeelding 2 van 3 Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: stap 2, afbeelding 3 van 3
      • Repeat the previous step for the screen adhesive.
      • Don't use metal tools to scrape away adhesive as this will damage the screen.
      • Don't use isopropyl alcohol near the front camera bracket as it will loosen its adhesive.
      Vraag FixBot
      Voeg opmerking toe
    3. Google Pixel 5 Screen Adhesive Installation, Align the adhesive: stap 3, afbeelding 1 van 2 Google Pixel 5 Screen Adhesive Installation, Align the adhesive: stap 3, afbeelding 2 van 2
      • Use the holes in the top right and bottom left corners of the frame to correctly align the adhesive:
      • The top right hole is circular
      • The bottom left hole is oblong
      Vraag FixBot
      Voeg opmerking toe
    4. Google Pixel 5 Screen Adhesive Installation, Prepare the adhesive: stap 4, afbeelding 1 van 1
      • Peel away the clear plastic lining to expose the frame side of the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    5. Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: stap 5, afbeelding 1 van 2 Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: stap 5, afbeelding 2 van 2
      • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
      • Lower the adhesive onto the frame.
      • Use the holes in the top right and bottom left corners to properly align the adhesive during installation.
      Vraag FixBot
      Voeg opmerking toe
    6. Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: stap 6, afbeelding 1 van 2 Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: stap 6, afbeelding 2 van 2
      • Use the flat end of a spudger or your fingernail to press down on the adhesive.
      • Slide along the perimeter to secure the adhesive to the frame.
      Vraag FixBot
      Voeg opmerking toe
    7. Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: stap 7, afbeelding 1 van 2 Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: stap 7, afbeelding 2 van 2
      • Use your fingers to grasp the blue plastic lining near the center and peel it away from the phone.
      • This should leave a thin perimeter of adhesive still covered by blue plastic lining.
      Vraag FixBot
      Voeg opmerking toe
    8. Google Pixel 5 Screen Adhesive Installation, Connect the screen: stap 8, afbeelding 1 van 2 Google Pixel 5 Screen Adhesive Installation, Connect the screen: stap 8, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    9. Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: stap 9, afbeelding 1 van 2 Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: stap 9, afbeelding 2 van 2
      • Peel away the blue plastic lining to expose the perimeter adhesive.
      Vraag FixBot
      Voeg opmerking toe
    10. Google Pixel 5 Screen Adhesive Installation, Position the screen: stap 10, afbeelding 1 van 3 Google Pixel 5 Screen Adhesive Installation, Position the screen: stap 10, afbeelding 2 van 3 Google Pixel 5 Screen Adhesive Installation, Position the screen: stap 10, afbeelding 3 van 3
      • Position the screen so it lays on the frame.
      Vraag FixBot
      Voeg opmerking toe
    11. Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: stap 11, afbeelding 1 van 2 Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: stap 11, afbeelding 2 van 2
      • Press down the corners of the screen to secure them to the frame.
      Vraag FixBot
      Voeg opmerking toe
    12. Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: stap 12, afbeelding 1 van 3 Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: stap 12, afbeelding 2 van 3 Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: stap 12, afbeelding 3 van 3
      • Press down on the edges of the screen.
      • Slide along the perimeter to secure it to the frame.
      • You can heat the perimeter of the screen to soften the adhesive and help it bond more securely.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 5 Answers community for help.
34 andere personen hebben deze handleiding voltooid.
Chayton Ritter
27.165 Reputatie
105 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
10 Leden
31.222 handleidingen geschreven
1Gids Commentaar
Vielen Dank für die ausführliche und hilfreiche Anleitung. Hat alles geklappt. Leider hatte ich die Schutzfolie über der Frontkamera übersehen. Die funktioniert jetzt nicht mehr. Das sollte noch in der Anleitung ergänzt werden.
Simon - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 184
Altijd: 13,703
