Ga door naar hoofdinhoud
Google Pixel 3 Back Cover Adhesive Installation
Wat je nodig hebt
  1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: stap 1, afbeelding 1 van 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: stap 1, afbeelding 2 van 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: stap 1, afbeelding 3 van 3
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    Vraag FixBot
    Voeg opmerking toe
  2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: stap 2, afbeelding 1 van 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: stap 2, afbeelding 2 van 3 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: stap 2, afbeelding 3 van 3
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
    Vraag FixBot
    Voeg opmerking toe
  3. Google Pixel 3 Back Cover Adhesive Installation, Prepare the replacement adhesive: stap 3, afbeelding 1 van 1
    • Peel away the clear plastic lining to expose the frame side of the replacement adhesive.
    Vraag FixBot
    Voeg opmerking toe
  4. Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: stap 4, afbeelding 1 van 2 Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: stap 4, afbeelding 2 van 2
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the rear camera and corners to properly align the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  5. Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: stap 5, afbeelding 1 van 2 Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: stap 5, afbeelding 2 van 2
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
    Vraag FixBot
    Voeg opmerking toe
  6. Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: stap 6, afbeelding 1 van 2 Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: stap 6, afbeelding 2 van 2
    • Peel away the blue outer plastic lining on the back cover side of the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  7. Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: stap 7, afbeelding 1 van 2 Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers or your fingers to position the fingerprint sensor cable over its connector on the motherboard.
    • Use the flat end of a spudger or your finger to press down on the connector to secure it to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  8. Google Pixel 3 Back Cover Adhesive Installation: stap 8, afbeelding 1 van 3 Google Pixel 3 Back Cover Adhesive Installation: stap 8, afbeelding 2 van 3 Google Pixel 3 Back Cover Adhesive Installation: stap 8, afbeelding 3 van 3
    • Use tweezers or your fingers to place the bracket over the fingerprint sensor cable.
    Vraag FixBot
    Voeg opmerking toe
  9. Google Pixel 3 Back Cover Adhesive Installation: stap 9, afbeelding 1 van 2 Google Pixel 3 Back Cover Adhesive Installation: stap 9, afbeelding 2 van 2
    • Use a Phillips PH00 screwdriver to install the two 4.1 mm screws securing the bracket to the frame.
    Vraag FixBot
    Voeg opmerking toe
  10. Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: stap 10, afbeelding 1 van 2 Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: stap 10, afbeelding 2 van 2
    • Peel away the red plastic lining to expose the back cover side of the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  11. Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: stap 11, afbeelding 1 van 2 Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: stap 11, afbeelding 2 van 2
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 Answers community for help.
11 andere personen hebben deze handleiding voltooid.
Chayton Ritter
26.963 Reputatie
105 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 79
Altijd: 4,597
