Wat je nodig hebt
First we heat the rear glass of the phone to melt all the adhesive that glues the glass to the rest of the phone. We can do it either with an iOpener or with a heat gun.
Now with a flat object or with an opening pick we cut the remaining adhesive by inserting it between the glass and the rest of the phone and passing it along the entire edge.
Now we can raise the back panel and we're done.
Unscrew the 6 Phillips #00 screws that weld the wireless charging base and the NFC antenna.
Disconnect the connector connecting the two antennas and remove everything.
Remove the 7 #00 Phillips screws that secure the charging board to the rest of the phone.
Remove the connector with your fingers or a flat tool.
Unscrew the 5 Phillips #00 screws that secure the front camera protector to the rest of the phone.
Remove the two Phillips #00 screws that secure the rear camera protector to the rest of the phone.
Unplug the three connectors of the three rear cameras and remove them.
Unscrew the three Phillips #00 screws that secure the docking board to the rest of the phone and then remove it.
With the special tab, detach it and pull to facilitate the removal of the battery.
Bereid je voor op toekomstige reparaties
Winkelen9Gids Commentaar
You beat iFixit to the punch! Nice work. They're really falling behind. Good thing we have awesome users like yourself! Thank you!
Thank You so much i really appreciate it thank you so much i really appreciate it
Will the microphone get damage if I wrongly insert the sim pin into it?
Mine did not damaged, all works properly)
