Ga door naar hoofdinhoud
Force Reboot PowerBook 180
David Kehley
David Kehley en een andere bijdrager
Voor het laatst geüpdatet op October 22, 2023
Geen schatting
Gemiddeld
Door de gemeenschap gemaakte handleiding
Betere introductie
  1. Force Reboot PowerBook 180, Force Reboot PowerBook 180: stap 1, afbeelding 1 van 1
    • To fully restart the power management unit be sure to remove the AC adapter and the battery first and let the PowerBook sit without power for several minutes.
    • Go to back of computer.
  2. Force Reboot PowerBook 180: stap 2, afbeelding 1 van 1
    • Have a pen or small enough object and push it into small hole closest to power button
    • You should hear the startup chime
  3. Force Reboot PowerBook 180: stap 3, afbeelding 1 van 1
    • If the computer still exhibits the same issue, repeat steps 1 and 2 and then follow the step listed below before reinstalling the battery.
    • Using two paper clips, simultaneously press and hold down the reset and interrupt buttons for 5 to 10 seconds.
Conclusie
David Kehley
101 Reputatie
1 Handleiding geschreven
Één opmerking
I have an old 180 and it turns on but all I get on screen is the icon with question mark. Each time I try to put in a floppy disk it ejects it every time. I’ve tried rebooting, unplugging so I guess I’m down to a target practice now. LOL
Jim Baskin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 1,210
