Ga door naar hoofdinhoud
Epson Home Cinema 2150 Projector Lamp Replacement
Luis Garcia
Luis Garcia en 2 andere bijdragers
Voor het laatst geüpdatet op April 5, 2023
2 - 8 minuten
Eenvoudig
A lamp replacement for the Epson Home Cinema 2150 will be needed if the projected image is not visible, projector lamp light is flashing orange and its power light is flashing blue, and if there is a message telling you to replace the lamp.
The Epson Home Cinema 2150 Lamp is located under an accessible panel for quick replacement. For this guide, only a Phillips #2 screwdriver is needed.
Wat je nodig hebt
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Epson Home Cinema 2150 Projector Lamp Replacement, Projector Lamp: stap 1, afbeelding 1 van 3 Epson Home Cinema 2150 Projector Lamp Replacement, Projector Lamp: stap 1, afbeelding 2 van 3 Epson Home Cinema 2150 Projector Lamp Replacement, Projector Lamp: stap 1, afbeelding 3 van 3
    • Disconnect and cool the device to room temperature. Failure to do so may result in electric shock or minor burns.
    • Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
    • Unscrew the single 6mm Phillips#2 holding screw from the access panel.
    • Slide the panel horizontally, then lift up to remove the access panel.
  2. Epson Home Cinema 2150 Projector Lamp Replacement: stap 2, afbeelding 1 van 3 Epson Home Cinema 2150 Projector Lamp Replacement: stap 2, afbeelding 2 van 3 Epson Home Cinema 2150 Projector Lamp Replacement: stap 2, afbeelding 3 van 3
    • Loosen and remove the two screws holding the lamp.
    • Remove two 9 mm Phillips #2 screws.
  3. Epson Home Cinema 2150 Projector Lamp Replacement: stap 3, afbeelding 1 van 3 Epson Home Cinema 2150 Projector Lamp Replacement: stap 3, afbeelding 2 van 3 Epson Home Cinema 2150 Projector Lamp Replacement: stap 3, afbeelding 3 van 3
    • Using four fingers, pull upwards on the lamp's plastic casing.
    • You may feel some resistance when pulling the lamp.
Conclusie
Luis Garcia
577 Reputatie
4 handleidingen geschreven
CSU Los Angeles, Team 6-2, Adachi Fall 2022 Lid van CSU Los Angeles, Team 6-2, Adachi Fall 2022
CSULA-ADACHI-F22S6G2
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 890
