Ga door naar hoofdinhoud
EVGA x17 Scroll Wheel Replacement
Sydney Puett
Sydney Puett en 4 andere bijdragers
Voor het laatst geüpdatet op December 27, 2023
30 - 40 minuten
Gemiddeld
If your EVGA x17 gaming mouse wheel doesn’t seem to register any movement, use this guide to replace the scroll wheel.
A scroll wheel is usually made of hard plastic with a rubber cover and located in between the left and right mouse clickers. A scroll wheel is intended for scrolling on a device. An unresponsive scroll wheel may be caused by a faulty USB port or incorrect mouse settings. Please refer to the troubleshooting page to explore the alternatives. This issue could also be caused by a build up of dirt or dust.
Click here to visit our guide on how to disassemble and clean the mouse.
Wat je nodig hebt
Gereedschap
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. EVGA x17 Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 1 van 1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Scroll Wheel Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel.
  3. EVGA x17 Scroll Wheel Replacement: stap 3, afbeelding 1 van 1
    • Remove the weight chamber cover.
  4. EVGA x17 Scroll Wheel Replacement: stap 4, afbeelding 1 van 1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
  5. EVGA x17 Scroll Wheel Replacement: stap 5, afbeelding 1 van 2 EVGA x17 Scroll Wheel Replacement: stap 5, afbeelding 2 van 2
    • Remove the 13 screws on the interior.
    • There are 2 Phillips truss-head tapping screws, large circular heads, and the 11 Phillips screws from the interior.
  6. EVGA x17 Scroll Wheel Replacement: stap 6, afbeelding 1 van 1
    • Carefully slide middle section out.
    • Remove smaller sized cross head screws from piece labeled AZAC001-A V1.0.
  7. EVGA x17 Scroll Wheel Replacement: stap 8, afbeelding 1 van 1
    • Pull the transistor from the side of the mouse wheel.
  8. EVGA x17 Scroll Wheel Replacement: stap 9, afbeelding 1 van 1
    • Carefully slide a spudger between the opaque plastic that holds the scroll wheel in place.
    • Pry the plastic away from the wheel, allowing for the scroll wheel to be removed.
  9. EVGA x17 Scroll Wheel Replacement: stap 10, afbeelding 1 van 2 EVGA x17 Scroll Wheel Replacement: stap 10, afbeelding 2 van 2
    • Remove scroll wheel cover and replace plastic wheel (or cover if that appears to be the issue).
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sydney Puett
599 Reputatie
3 handleidingen geschreven
Één opmerking
Is there a wheel that can be purchased that will fit or can be modified to fit for the replacement.
Ronald Winfrey - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 102
Altijd: 1,571
