Ga door naar hoofdinhoud
Dell Vostro 3550 Disk Drive Tray Latch Replacement
Dylan J. Souza
Dylan J. Souza en 2 andere bijdragers
Voor het laatst geüpdatet op July 14, 2019
7 minuten
Eenvoudig
This guide will guide the user through all of the necessary steps to replace the disk drive tray latch on their Dell Vostro 3550. This component may need to be replaced if the user notices that the tray will not eject or close properly. The cause of this problem is that the latch mechanism is broken inside the disk tray. This is a common problem that occurs when users close their disk drive with a lot of force.
Wat je nodig hebt
Gereedschap
  1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: stap 1, afbeelding 1 van 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: stap 1, afbeelding 2 van 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: stap 1, afbeelding 3 van 3
    • Push a paperclip that is bent straight into the small pin hole on the right of the release button.
    • When 3/4" of the paperclip is inserted the tray will pop open.
    • Pull the disk tray out as far as it will extend.
  2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: stap 2, afbeelding 1 van 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: stap 2, afbeelding 2 van 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: stap 2, afbeelding 3 van 3
    • Flip the laptop over and position it so the disk drive is in front of you.
    • Remove the five 5mm Phillips #0 screws fastening the top plate to the disk tray.
  3. Dell Vostro 3550 Disk Drive Tray Latch Replacement: stap 3, afbeelding 1 van 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: stap 3, afbeelding 2 van 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: stap 3, afbeelding 3 van 3
    • Remove the top plate of the disk tray and place it off to the side.
  4. Dell Vostro 3550 Disk Drive Tray Latch Replacement: stap 4, afbeelding 1 van 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: stap 4, afbeelding 2 van 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: stap 4, afbeelding 3 van 3
    • Remove the single 5mm Phillips #0 screw securing the latch mechanism to the disk drive.
    • Pull the damaged latch away from the disk drive and replace with the new latch.
Conclusie
Dylan J. Souza
781 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S8-G6, Bailey Spring 2019 Lid van UMass Dartmouth, Team S8-G6, Bailey Spring 2019
UMASSD-BAILEY-S19S8G6
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 280
