Dell Latitude E4200 SSD Replacement
Inleiding
Ga naar stap 1Follow these steps in order to successfully replace the SSD of your laptop.
Wat je nodig hebt
Gereedschap
Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
6 andere personen hebben deze handleiding voltooid.
Één opmerking
You can use any mSATA SSD as replacement by using the following caddy/adapter:
