Ga door naar hoofdinhoud
Dell Inspiron M5110 Palmrest Replacement
Larain
Larain en 3 andere bijdragers
Voor het laatst geüpdatet op December 22, 2016
Geen schatting
Gemiddeld
I am going to explain how to remove the palmrest of the laptop to reach its main board, and other components.
Wat je nodig hebt
Gereedschap
  1. Dell Inspiron M5110 Palmrest Replacement, Battery: stap 1, afbeelding 1 van 1
    • Shut down the computer and turn it upside down.
  2. Dell Inspiron M5110 Palmrest Replacement: stap 2, afbeelding 1 van 1
    • Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
  3. Dell Inspiron M5110 Palmrest Replacement: stap 3, afbeelding 1 van 1
    • Slide and lift the battery up and out from the device.
  4. Dell Inspiron M5110 Palmrest Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Open the computer and push the screen back as far as possible.
  5. Dell Inspiron M5110 Palmrest Replacement: stap 5, afbeelding 1 van 1
    • Slide a plastic opening tool into the slots on the top of the keyboard.
  6. Dell Inspiron M5110 Palmrest Replacement: stap 6, afbeelding 1 van 1
    • Pry the keyboard away from the device using the plastic opening tool.
  7. Dell Inspiron M5110 Palmrest Replacement: stap 7, afbeelding 1 van 1
    • Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
  8. Dell Inspiron M5110 Palmrest Replacement: stap 8, afbeelding 1 van 1
    • Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
  9. Dell Inspiron M5110 Palmrest Replacement: stap 9, afbeelding 1 van 1
    • Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
  10. Dell Inspiron M5110 Palmrest Replacement, Palmrest: stap 10, afbeelding 1 van 1
    • Turn the computer over and remove the six screws that secure the palmrest assembly
  11. Dell Inspiron M5110 Palmrest Replacement: stap 11, afbeelding 1 van 1
    • Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
  12. Dell Inspiron M5110 Palmrest Replacement: stap 12, afbeelding 1 van 2 Dell Inspiron M5110 Palmrest Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
  13. Dell Inspiron M5110 Palmrest Replacement: stap 13, afbeelding 1 van 2 Dell Inspiron M5110 Palmrest Replacement: stap 13, afbeelding 2 van 2
    • Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Larain
387 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 4-3, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-3, Catania Fall 2016
UMASSD-CATANIA-F16S4G3
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 199
