Ga door naar hoofdinhoud
Dell Inspiron 8600 Touch Pad Replacement
John Nesthus
John Nesthus en 8 andere bijdragers
Voor het laatst geüpdatet op January 10, 2025
1 - 2 uren
Gemiddeld
Actiemomenten
Behoeft meer afbeeldingen
Onjuiste gereedschappen
Ontbrekende stappen
Betere introductie
In this guide, you will learn how to replace the touchpad on the Dell Inspiron 8600. The touchpad is used to scroll and click on links and items that are being presented on your screen without this function working properly your computer is ineffective.
Before you start the repair, make sure your laptop is powered off and it is unplugged from the charger.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Dell Inspiron 8600 Touch Pad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: stap 2, afbeelding 1 van 3 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: stap 2, afbeelding 2 van 3 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: stap 2, afbeelding 3 van 3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Touch Pad Replacement: stap 3, afbeelding 1 van 1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Touch Pad Replacement, Keyboard: stap 4, afbeelding 1 van 3 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: stap 4, afbeelding 2 van 3 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: stap 4, afbeelding 3 van 3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Touch Pad Replacement, Display Module: stap 5, afbeelding 1 van 2 Dell Inspiron 8600 Touch Pad Replacement, Display Module: stap 5, afbeelding 2 van 2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Touch Pad Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Touch Pad Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 8600 Touch Pad Replacement: stap 7, afbeelding 2 van 2
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Touch Pad Replacement: stap 8, afbeelding 1 van 1
    • Now remove the display module.
  9. Dell Inspiron 8600 Touch Pad Replacement, Touch Pad: stap 9, afbeelding 1 van 1
    • Remove the palm rest assembly that secures the touch pad from the device.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
John Nesthus
186 Reputatie
6 handleidingen geschreven
Cal Poly, Team 18-22, Garner Spring 2011 Lid van Cal Poly, Team 18-22, Garner Spring 2011
CPSU-GARNER-S11S18G22
4 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 20
Altijd: 3,096
