Ga door naar hoofdinhoud
Dell Inspiron 530 DCMF RAM Replacement
Drew Cunningham
Drew Cunningham en 4 andere bijdragers
Voor het laatst geüpdatet op August 15, 2019
5 - 10 minuten
Eenvoudig
Heeft betere plaatjes nodig
Replacing the RAM is simple, push down a snap to unlock it, pull it out then push the new one into place.
Wat je nodig hebt
Gereedschap
  1. Dell Inspiron 530 DCMF RAM Replacement, RAM: stap 1, afbeelding 1 van 2 Dell Inspiron 530 DCMF RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Locate and unscrew the two large screws at the back of the computer. Once the screws are removed, the panel on the right side will slide towards the back, and release itself. Lift the panel off the computer to reveal the internals.
  2. Dell Inspiron 530 DCMF RAM Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 530 DCMF RAM Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 530 DCMF RAM Replacement: stap 2, afbeelding 3 van 3
    • The RAM will be located on the main circuit board, known as the motherboard. There should be two chips in parallel with each other, both sticking up at a 90-degree angle.
    • On both ends of the RAM chip, there will be white tabs. Push down on these tabs to release the chip from the motherboard.
    • Pull up on the RAM chip to remove it.
    • Do not touch the gold edge of the chip. The oils on your hands can damage it.
  3. Dell Inspiron 530 DCMF RAM Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 530 DCMF RAM Replacement: stap 3, afbeelding 2 van 2
    • When inserting the new chip, find the open slot you just took one out of, and then line up the pins on the stick with the holes in the slot, then push down firmly.
    • Once the RAM is in, make sure to push up the white tabs on each side to lock it in place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Drew Cunningham
656 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-1, Kish Spring 2015 Lid van UMass Dartmouth, Team 5-1, Kish Spring 2015
UMASSD-KISH-S15S5G1
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 1,063
