Ga door naar hoofdinhoud
Dell Inspiron 530 DCMF RAM Replacement
Engels
Nederlands
Stap 2
Dell Inspiron 530 DCMF RAM Replacement: stap 0, afbeelding 1 van 3 Dell Inspiron 530 DCMF RAM Replacement: stap 0, afbeelding 2 van 3 Dell Inspiron 530 DCMF RAM Replacement: stap 0, afbeelding 3 van 3
  • The RAM will be located on the main circuit board, known as the motherboard. There should be two chips in parallel with each other, both sticking up at a 90-degree angle.
  • On both ends of the RAM chip, there will be white tabs. Push down on these tabs to release the chip from the motherboard.
  • Pull up on the RAM chip to remove it.
  • Do not touch the gold edge of the chip. The oils on your hands can damage it.
Vertaling hier toevoegen
