Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement
Inleiding
Ga naar stap 1The base cover of the Dell Inspiron 17" 7786 2-in-1 laptop is made with silver aluminum-clad, holding 3 captive screws near the area where the hinges are located.
While the device does have good ventilation for everyday usage, it would be advised to remove the casing to clean any hidden dust and debris.
Wat je nodig hebt
Gereedschap
Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
