Ga door naar hoofdinhoud
Dell 1350cnw Fuser Unit Replacement
Jac
Jac en een andere bijdrager
Voor het laatst geüpdatet op November 9, 2024
15 - 30 minuten
Gemiddeld
Door de gemeenschap gemaakte handleiding
The fuser unit is located at the top of the printer, and bonds the powdered toner onto the paper through applying high temperature and pressure. If this unit isn't working, this guide will show how to access and replace it.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Dell 1350cnw Fuser Unit Replacement, Unclip front top band: stap 1, afbeelding 1 van 2 Dell 1350cnw Fuser Unit Replacement, Unclip front top band: stap 1, afbeelding 2 van 2
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
  2. Dell 1350cnw Fuser Unit Replacement, Unclip front top band: stap 2, afbeelding 1 van 2 Dell 1350cnw Fuser Unit Replacement, Unclip front top band: stap 2, afbeelding 2 van 2
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
  3. Dell 1350cnw Fuser Unit Replacement, Remove front top band: stap 3, afbeelding 1 van 1
    • Tilt the top of the front band away from the printer and lift away to remove.
  4. Dell 1350cnw Fuser Unit Replacement, Remove left-side top band: stap 4, afbeelding 1 van 3 Dell 1350cnw Fuser Unit Replacement, Remove left-side top band: stap 4, afbeelding 2 van 3 Dell 1350cnw Fuser Unit Replacement, Remove left-side top band: stap 4, afbeelding 3 van 3
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
  5. Dell 1350cnw Fuser Unit Replacement, Remove control panel module: stap 5, afbeelding 1 van 3 Dell 1350cnw Fuser Unit Replacement, Remove control panel module: stap 5, afbeelding 2 van 3 Dell 1350cnw Fuser Unit Replacement, Remove control panel module: stap 5, afbeelding 3 van 3
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
  6. Dell 1350cnw Fuser Unit Replacement, Remove front cover: stap 6, afbeelding 1 van 1
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
  7. Dell 1350cnw Fuser Unit Replacement, Remove front cover: stap 7, afbeelding 1 van 1
    • Remove both 7mm phillips screws securing the front cover in place.
  8. Dell 1350cnw Fuser Unit Replacement, Remove front cover: stap 8, afbeelding 1 van 3 Dell 1350cnw Fuser Unit Replacement, Remove front cover: stap 8, afbeelding 2 van 3 Dell 1350cnw Fuser Unit Replacement, Remove front cover: stap 8, afbeelding 3 van 3
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
  9. Dell 1350cnw Fuser Unit Replacement, Remove front cover: stap 9, afbeelding 1 van 1
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
  10. Dell 1350cnw Fuser Unit Replacement, Remove top cover: stap 10, afbeelding 1 van 2 Dell 1350cnw Fuser Unit Replacement, Remove top cover: stap 10, afbeelding 2 van 2
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
  11. Dell 1350cnw Fuser Unit Replacement, Remove top cover: stap 11, afbeelding 1 van 2 Dell 1350cnw Fuser Unit Replacement, Remove top cover: stap 11, afbeelding 2 van 2
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
  12. Dell 1350cnw Fuser Unit Replacement, Remove top cover: stap 12, afbeelding 1 van 1
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
  13. Dell 1350cnw Fuser Unit Replacement, Remove top cover: stap 13, afbeelding 1 van 1
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
  14. Dell 1350cnw Fuser Unit Replacement, Remove top cover: stap 14, afbeelding 1 van 1
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
  15. Dell 1350cnw Fuser Unit Replacement, Remove side cover: stap 15, afbeelding 1 van 3 Dell 1350cnw Fuser Unit Replacement, Remove side cover: stap 15, afbeelding 2 van 3 Dell 1350cnw Fuser Unit Replacement, Remove side cover: stap 15, afbeelding 3 van 3
    • Unclip the back edge of the side cover by prying away from the printer back panel.
    • Pull the top of the side panel away from the printer.
    • Lift up the printer from underneath to release the bottom clips, and the side panel drops away from the printer.
  16. Dell 1350cnw Fuser Unit Replacement, Remove back cover: stap 16, afbeelding 1 van 1
    • Remove the four 7mm phillips screws holding the rear cover to the printer.
  17. Dell 1350cnw Fuser Unit Replacement, Unplug sensor cable: stap 17, afbeelding 1 van 2 Dell 1350cnw Fuser Unit Replacement, Unplug sensor cable: stap 17, afbeelding 2 van 2
    • Pull out the connector for the rear cover sensor from the power supply board.
    • De-route the light pink coloured pair of sensor cables and remove from the wiring harness.
  18. Dell 1350cnw Fuser Unit Replacement, Remove back cover: stap 18, afbeelding 1 van 1
    • Unclip the rear cover opposite the de-routed cables by prying away from the rest of the printer using a prying tool.
    • The rear cover can now be removed from the printer.
  19. Dell 1350cnw Fuser Unit Replacement, Remove fuser unit: stap 19, afbeelding 1 van 2 Dell 1350cnw Fuser Unit Replacement, Remove fuser unit: stap 19, afbeelding 2 van 2
    • Unscrew the 9mm phillips screw.
    • Unscrew the 9mm Torx TR10 security screw.
  20. Dell 1350cnw Fuser Unit Replacement, Remove fuser unit: stap 20, afbeelding 1 van 3 Dell 1350cnw Fuser Unit Replacement, Remove fuser unit: stap 20, afbeelding 2 van 3 Dell 1350cnw Fuser Unit Replacement, Remove fuser unit: stap 20, afbeelding 3 van 3
    • Unplug the fuser power cable by squeezing the top of the retaining clip and pulling the connector up from the power supply board.
    • De-route the fuser power cable and remove from the cable restraint.
    • Pull up on the two fuser unit control cable connectors to unplug from the control board.
    • De-route the two sets of control cables from the control board to the fuser unit and remove from the wiring harness.
  21. Dell 1350cnw Fuser Unit Replacement, Remove fuser unit: stap 21, afbeelding 1 van 2 Dell 1350cnw Fuser Unit Replacement, Remove fuser unit: stap 21, afbeelding 2 van 2
    • Lift up fuser unit to remove from the printer.
Conclusie
Jac
2.728 Reputatie
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 35
