Ga door naar hoofdinhoud
Core Assembly Removal
Wat je nodig hebt
  1. Core Assembly Removal, Power down your watch: stap 1, afbeelding 1 van 2 Core Assembly Removal, Power down your watch: stap 1, afbeelding 2 van 2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    Vraag FixBot
    Voeg opmerking toe
  2. Core Assembly Removal, Unfasten the back cover: stap 2, afbeelding 1 van 1
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
    Vraag FixBot
    Voeg opmerking toe
  3. Core Assembly Removal, Loosen the back cover adhesive: stap 3, afbeelding 1 van 1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Vraag FixBot
    Voeg opmerking toe
  4. Core Assembly Removal, Pry up the back cover assembly: stap 4, afbeelding 1 van 3 Core Assembly Removal, Pry up the back cover assembly: stap 4, afbeelding 2 van 3 Core Assembly Removal, Pry up the back cover assembly: stap 4, afbeelding 3 van 3
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
    Vraag FixBot
    Voeg opmerking toe
  5. Core Assembly Removal, Disconnect the sensor assembly cable: stap 5, afbeelding 1 van 2 Core Assembly Removal, Disconnect the sensor assembly cable: stap 5, afbeelding 2 van 2
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Vraag FixBot
    Voeg opmerking toe
  6. Core Assembly Removal, Remove the back cover assembly: stap 6, afbeelding 1 van 3 Core Assembly Removal, Remove the back cover assembly: stap 6, afbeelding 2 van 3 Core Assembly Removal, Remove the back cover assembly: stap 6, afbeelding 3 van 3
    • Remove the back cover assembly.
    Vraag FixBot
    Voeg opmerking toe
  7. Core Assembly Removal, Disconnect the microphone cable: stap 7, afbeelding 1 van 2 Core Assembly Removal, Disconnect the microphone cable: stap 7, afbeelding 2 van 2
    • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
    Vraag FixBot
    Voeg opmerking toe
  8. Core Assembly Removal, Unfasten the core assembly: stap 8, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
    Vraag FixBot
    Voeg opmerking toe
  9. Core Assembly Removal, Pry up the core assembly: stap 9, afbeelding 1 van 2 Core Assembly Removal, Pry up the core assembly: stap 9, afbeelding 2 van 2
    • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
    • Pry upwards to loosen the core assembly.
    • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
    Vraag FixBot
    Voeg opmerking toe
  10. Core Assembly Removal, Swing open the core assembly: stap 10, afbeelding 1 van 3 Core Assembly Removal, Swing open the core assembly: stap 10, afbeelding 2 van 3 Core Assembly Removal, Swing open the core assembly: stap 10, afbeelding 3 van 3
    • Carefully swing open the core assembly like the front cover of a book.
    • Avoid straining or tearing the display cables at the bottom of the core assembly.
    Vraag FixBot
    Voeg opmerking toe
  11. Core Assembly Removal, Disconnect the display cables: stap 11, afbeelding 1 van 3 Core Assembly Removal, Disconnect the display cables: stap 11, afbeelding 2 van 3 Core Assembly Removal, Disconnect the display cables: stap 11, afbeelding 3 van 3
    • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
    Vraag FixBot
    Voeg opmerking toe
  12. Core Assembly Removal, Remove the core assembly: stap 12, afbeelding 1 van 2 Core Assembly Removal, Remove the core assembly: stap 12, afbeelding 2 van 2
    • Remove the core assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Dominik Schnabelrauch
260.495 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
27.484 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 42
Altijd: 1,510
