Canon EOS 6D Rear LCD Screen Replacement
Inleiding
Ga naar stap 1Use this guide to replace a cracked or malfunctioning rear LCD screen on your EOS 6D.
Wat je nodig hebt
Remove the viewfinder cover by pinching the sides and sliding it upward.
Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
Rotate the covers to the side so that you can see the connection ports inside.
Remove the following screws:
Two silver 5mm Phillips #00
One black 6mm Phillips #00
Gereedschap gebruikt in deze stap:Tweezers$4.99
Detach the two light brown ribbon wires from the back of the LCD screen by firmly gripping each with tweezers and gently pulling straight to the left.
12 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Thank you! Thank you!! I rescued my 6D. All your steps and details were very useful.
Few points to add:
1. I think the black screw (yellow circle) from step 7 is 3 mm.
2. Lift the light brown flap that holds the ribbon cable before removing the LCD panel.
3. When you remove the LCD panel from the metal housing, you will have to pry the two strips of adhesive that is there.
4. Be careful when tightening the screws back.
