Ga door naar hoofdinhoud
CAT S22 Flip Battery Replacement
Wat je nodig hebt
    1. CAT S22 Flip Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Unscrew the large screw on the back of the phone using a flathead screwdriver or coin.
      • The screw will always be completely unscrewed after 4 full counter-clockwise rotations.
      • The screw cannot be completely removed so that you can’t lose the screw.
      Vraag FixBot
      Voeg opmerking toe
    2. CAT S22 Flip Battery Replacement: stap 2, afbeelding 1 van 1
      • There is a slot on the upper left side of the back plate to insert the Spudger.
      • Use a spudger to pry up the back plate.
      Vraag FixBot
      Voeg opmerking toe
    3. CAT S22 Flip Battery Replacement: stap 3, afbeelding 1 van 1
      • There is a slot to insert a spudger at the bottom of the battery.
      • Use a spudger to lift the battery out of the phone.
      • Do not operate on a devise with a swollen battery. Do not dispose of a swollen battery into general waste systems. You can dispose of the batteries with a qualified technician or facility.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Stephan Shaffer
234 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 91
Altijd: 331
