Ga door naar hoofdinhoud
Blink Video Doorbell Speaker Replacement
Wat je nodig hebt
  1. Blink Video Doorbell Speaker Replacement, Battery: stap 1, afbeelding 1 van 3 Blink Video Doorbell Speaker Replacement, Battery: stap 1, afbeelding 2 van 3 Blink Video Doorbell Speaker Replacement, Battery: stap 1, afbeelding 3 van 3
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Speaker Replacement: stap 2, afbeelding 1 van 3 Blink Video Doorbell Speaker Replacement: stap 2, afbeelding 2 van 3 Blink Video Doorbell Speaker Replacement: stap 2, afbeelding 3 van 3
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Speaker Replacement: stap 3, afbeelding 1 van 3 Blink Video Doorbell Speaker Replacement: stap 3, afbeelding 2 van 3 Blink Video Doorbell Speaker Replacement: stap 3, afbeelding 3 van 3
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Speaker Replacement, Back Panel: stap 4, afbeelding 1 van 3 Blink Video Doorbell Speaker Replacement, Back Panel: stap 4, afbeelding 2 van 3 Blink Video Doorbell Speaker Replacement, Back Panel: stap 4, afbeelding 3 van 3
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
  5. Blink Video Doorbell Speaker Replacement, Speaker: stap 5, afbeelding 1 van 3 Blink Video Doorbell Speaker Replacement, Speaker: stap 5, afbeelding 2 van 3 Blink Video Doorbell Speaker Replacement, Speaker: stap 5, afbeelding 3 van 3
    • Remove the three 6 mm screws from the upper part of the motherboard using a JIS #1 screwdriver.
    • Use an opening tool to release the motherboard from the device.
  6. Blink Video Doorbell Speaker Replacement: stap 6, afbeelding 1 van 3 Blink Video Doorbell Speaker Replacement: stap 6, afbeelding 2 van 3 Blink Video Doorbell Speaker Replacement: stap 6, afbeelding 3 van 3
    • Use tweezers to detach the white connector from the adapter on the motherboard.
    • Remove the speaker.
Conclusie
LisbethRivas_
90 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-1, Konn Fall 2024 Lid van UMass Dartmouth, Team 1-1, Konn Fall 2024
UMASSD-KONN-F24S1G1
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 20
Altijd: 360
