Ga door naar hoofdinhoud
Bissell Air180 Motherboard Replacement
Aleah Ramos
Aleah Ramos en 2 andere bijdragers
Voor het laatst geüpdatet op December 19, 2022
10 minuten
Gemiddeld
The motherboard on the Bissell Air180 is located inside the fan housing. It is the main circuit board for the air purifier which is responsible for allowing communications between the power supply, control buttons, and the fan speed and timer knob. If the air purifier is not working properly or is shutting off unexpectedly, then refer to our "Air purifier is non-responsive" troubleshooting guide or follow these steps to replace the motherboard.
Wat je nodig hebt
Gereedschap
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  1. Bissell Air180 Motherboard Replacement, Air Filter: stap 1, afbeelding 1 van 2 Bissell Air180 Motherboard Replacement, Air Filter: stap 1, afbeelding 2 van 2
    • Squeeze the clip on the back panel of the bottom housing and pull the panel away from the housing, exposing the air filter.
  2. Bissell Air180 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Grab the sides of the filter and pull it up.
  3. Bissell Air180 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Pull the filter away from the bottom housing, removing it from the rest of the device.
  4. Bissell Air180 Motherboard Replacement, Power Supply: stap 4, afbeelding 1 van 1
    • Remove the four 18mm Phillips #1 screws connecting the bottom housing to the rest of the device.
  5. Bissell Air180 Motherboard Replacement: stap 5, afbeelding 1 van 3 Bissell Air180 Motherboard Replacement: stap 5, afbeelding 2 van 3 Bissell Air180 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Pull the bottom housing away from the rest of the device separating the power supply.
    • Unplug the red cord to fully disconnect the power supply from the fan and motherboard housing.
  6. Bissell Air180 Motherboard Replacement, Control Buttons: stap 6, afbeelding 1 van 3 Bissell Air180 Motherboard Replacement, Control Buttons: stap 6, afbeelding 2 van 3 Bissell Air180 Motherboard Replacement, Control Buttons: stap 6, afbeelding 3 van 3
    • Pry off the top vent, separating it from the fan and motherboard housing.
  7. Bissell Air180 Motherboard Replacement: stap 7, afbeelding 1 van 2 Bissell Air180 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Pry the button control panel up and away from the rest of the device using a spudger.
  8. Bissell Air180 Motherboard Replacement: stap 8, afbeelding 1 van 2 Bissell Air180 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Pull the wire connecting the button controls to the fan housing to fully disconnect the button controls from the device.
  9. Bissell Air180 Motherboard Replacement, Fan: stap 9, afbeelding 1 van 3 Bissell Air180 Motherboard Replacement, Fan: stap 9, afbeelding 2 van 3 Bissell Air180 Motherboard Replacement, Fan: stap 9, afbeelding 3 van 3
    • Flip the motherboard and fan housing upside down to find where to disconnect the fan from the rest of the device.
    • Remove the two 11 mm screws using a Phillips #1 screwdriver.
    • Detach the two wires connecting the fan to the motherboard so the fan is now loose inside the housing.
  10. Bissell Air180 Motherboard Replacement: stap 10, afbeelding 1 van 2 Bissell Air180 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Flip the motherboard and fan housing back over and pull the fan up separating it from the rest of the device.
  11. Bissell Air180 Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 2 Bissell Air180 Motherboard Replacement, Motherboard: stap 11, afbeelding 2 van 2
    • Apply pressure and push out the control knob to remove the motherboard from the rest of the device.
    • Removing the two 11mm Phillips #1 screws when disconnecting the fan also disconnected the motherboard from the rest of the device.
Conclusie
Aleah Ramos
533 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 3-4, Botvin Fall 2022 Lid van UMass Dartmouth, Team 3-4, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 121
