Asus X553MA-BPD07051 Battery Replacement
Inleiding
Ga naar stap 1If you are having issues with your AsusX553MA-BPD07051 holding a charge, and you have identified that the issue is not the power cord adapter, the problem is most likely with the battery itself. Once you have identified that your battery does not function properly and needs to be replaced, this guide will allow for simple removal of the battery. Ensure that before working on your laptop, the laptop is completely turned off. For more troubleshooting assistance, check out this link. Before opening up the laptop, ensure that the device has been powered off to avoid being shocked.
Wat je nodig hebt
Gereedschap
Toon meer…
Video overzicht
Use a Phillips #0 screwdriver (PH0 bit) to remove the four 5.0 mm screws that are securing the bottom of the laptop.
Use a Phillips #0 screwdriver (PH0 bit) to remove the six 11.0 mm screws that are securing the bottom of the laptop.
5 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Easy with the use of these clear instructions. Thanks and keep up the good work.
