Ga door naar hoofdinhoud
Asus X202E-UH31T Speaker Replacement
Brandon Bloomfield
Brandon Bloomfield en 3 andere bijdragers
Voor het laatst geüpdatet op January 5, 2018
15 minuten
Gemiddeld
This guide will show you how to replace the two speakers in your device.
Wat je nodig hebt
Gereedschap
  1. Asus X202E-UH31T Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Remove the 9 1.2mm phillips head screws off the back of the computer by using a small phillips head screw driver.
    • Start by disconnecting the battery cable/ribbon.
  2. Asus X202E-UH31T Speaker Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to open the components of the laptop. In order to do this, insert the plastic opening tool in between the two covers then pry open.
  3. Asus X202E-UH31T Speaker Replacement: stap 3, afbeelding 1 van 1
    • Once the back is off the device, locate the speakers. Remove the 7 1.2mm phillips head screws holding battery in place. Use a small phillips head screw driver.
    • Disconnect the battery ribbon and remove the battery.
  4. Asus X202E-UH31T Speaker Replacement: stap 4, afbeelding 1 van 1
    • Use a long plastic pry tool to remove the speaker from the computer. Note: There is strong adhesive holding the speaker down.
  5. Asus X202E-UH31T Speaker Replacement: stap 5, afbeelding 1 van 2 Asus X202E-UH31T Speaker Replacement: stap 5, afbeelding 2 van 2
    • Lift current speaker up and follow the wire to the remaining speaker.
    • Repeat previous step to remove second speaker from adhesive.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 251
