Asus X202E-UH31T Cooling Fan Replacement
7 minuten
Eenvoudig
Inleiding
Ga naar stap 1This guide is a simple guide to replace a faulty cooling fan which could lead to your device running at a hotter temperature than usual.
Wat je nodig hebt
Gereedschap
Remove the 9 1.2mm phillips head screws off the back of the computer using the small phillips head screw driver. Start by disconnecting the battery cable/ribbon.
Bijna klaar!
Conclusie
