Asus X200MA Hard Drive Replacement
Wat je nodig hebt
Reparatiesets
Deze sets bevatten alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
Toon meer…
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
Look at comments in the previous step. There are 2 more screws.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
There are also two other screws under the rubber feet above the battery.
digg1024 - Antwoord
I agree. Two another 14 mm screws under the rubber feet.
shao.onii - Antwoord
