Ga door naar hoofdinhoud
Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement
Gunnar Hudson
Gunnar Hudson en 6 andere bijdragers
Voor het laatst geüpdatet op January 5, 2021
25 minuten
Gemiddeld
The motherboard is a critical part of any computer, housing the central processor unit that data flows through. The Asus ROG Strix GL702VM-BHI7N09 gaming laptop is no exception and cannot function without a working motherboard. The guide below displays how to properly replace this component. Before starting the replacement of the motherboard, it is important to have some prior background knowledge about the components of a gaming laptop. It is also vital to power off the device, remove it from any external charging cable and disconnect or remove the battery prior to beginning the repair.
Wat je nodig hebt
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 2 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 2, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 2, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Battery: stap 3, afbeelding 1 van 1
    • Unplug the battery from the motherboard.
  4. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 4, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 4, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the 3.8 mm Phillips #1 screw on the top right hand corner of the battery.
    • Lift battery from laptop frame.
  5. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  6. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
  7. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Fan: stap 7, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the four indicated 4 mm screws that hold the black fan and the silver one adjacent to it.
  8. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • The smaller black fan must be removed before the larger gray fan on the right can be taken out.
    • To remove the black fan, pull gently on the connecting cables outlined.
  9. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Unplug the white connector by gently pulling the cables.
    • Lift off the gray fan.
  10. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the two indicated 4 mm screws from the other gray fan.
  11. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 11, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 11, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Unplug the white connector by gently pulling it towards the center of the computer.
    • Lift the fan out of the body of the laptop to remove it.
  12. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Motherboard: stap 12, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement, Motherboard: stap 12, afbeelding 3 van 3
    • Disconnect the speakers connectors located in each of the bottom corners.
    • Gently pull the wire up from the motherboard.
    • Once the wire is disconnected, pull the speaker out.
  13. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 13, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 13, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Gently lift the graphics card from the motherboard.
  14. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 14, afbeelding 1 van 2 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Use reverse pliers to detach ribbon connectors from the motherboard.
  15. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 15, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 15, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Remove each of the 4.7 mm Phillips #1 screws marked by a white arrow on the motherboard.
    • Remove the 6.7 mm Phillips #1 screws from the metal latches on the hinge-side corners.
    • The 4.7 mm Phillips #1 screw on the far left of the motherboard is covered by the black connecting wire in Step 5.
  16. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 16, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 16, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 16, afbeelding 3 van 3
    • Gently pull on black connecting wire to disconnect the monitor screen from the motherboard.
    • This will uncover the far left 4.7 mm Phillips #1 screw.
  17. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 17, afbeelding 1 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 17, afbeelding 2 van 3 Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 17, afbeelding 3 van 3
    • Lift the metal latches on both sides.
    • This can be easily done by opening the laptop after the metal latch screws have been removed.
  18. Asus ROG Strix GL702VM-BHI7N09 Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Remove the motherboard from the laptop frame.
    • You will need to pull the motherboard to the side as well as lifting it to free its various ports from the sides of the laptop case.
    • There is adhesive attaching the final ribbon connector to the bottom of the motherboard. This will need to be removed.
Conclusie
Gunnar Hudson
248 Reputatie
2 handleidingen geschreven
1Gids Commentaar
OK but where can I actually buy the replacement motherboard?
Hank Muller - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 33
Altijd: 3,410
