Ga door naar hoofdinhoud
Asus Q200E-CT144H Back Cover Replacement
Kirsti Wattles
Kirsti Wattles en een andere bijdrager
Voor het laatst geüpdatet op November 27, 2019
5 minuten
Eenvoudig
The overall purpose of having the back cover attached to the Asus Q200E-CT144H laptop is to protect what is stored within the laptop. If the back cover of your laptop is damaged, this can affect the components which are withheld inside the laptop. This can include the battery, fan, speaker, etc. The last thing you would want is for something to happen to the back cover, and if something has already happened to the back cover you can use this guide to assist you in replacing the back cover.
Wat je nodig hebt
Gereedschap
  1. Asus Q200E-CT144H Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • To start, turn off the laptop and disconnect the power cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Flip the laptop over so the back panel is visible.
  2. Asus Q200E-CT144H Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
  3. Asus Q200E-CT144H Back Cover Replacement: stap 3, afbeelding 1 van 2 Asus Q200E-CT144H Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Use an iFixit opening tool to lift the back cover and remove it from the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 171
