Asus N56VM Motherboard Replacement
Wat je nodig hebt
Remove the M2x4 screw of the bottom cover
Remove the bottom cover by sliding it downwards
Hold the upper part with one hand, and use your other hand to disconnect the black&white cable (antenna for the wifi card)
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Can you please help me locate the gpu VRM on the motherboard? My gpu is faulty and needs to be rebonded, so I wanna permanently disable it.
Sorry, I can’t help you with that
Stanky -
