Ga door naar hoofdinhoud
Anki Cozmo Battery Replacement
Marisa Gay
Marisa Gay en 3 andere bijdragers
Voor het laatst geüpdatet op April 5, 2024
45 minuten - 1 uur
Gemiddeld
Knip- en plakwerk
If your Anki Cozmo robot keeps turning off or the screen does not come on, follow this guide. This guide is to assist users replacing the battery in an Anki Cozmo robot, so it can come back to life. The battery, located inside Cozmo’s base, allows it to survive. Without a functioning battery, nothing else will work. Before beginning, make sure to power off your Anki Cozmo robot and disconnect it from the Anki Cozmo app.
WARNING: when using hands to remove any component, be careful not to cut yourself or rip your fingernail.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Anki Cozmo Battery Replacement, Speaker: stap 1, afbeelding 1 van 2 Anki Cozmo Battery Replacement, Speaker: stap 1, afbeelding 2 van 2
    • Remove the two black rubber treads from the wheels using your hands to pull them off.
  2. Anki Cozmo Battery Replacement: stap 2, afbeelding 1 van 2 Anki Cozmo Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the white hubcap from each of the four wheels using the metal spudger to pry them off.
    • There are four white hubcaps removed in this step. If your Cozmo is a different color, the hubcaps will also be the same color.
    Note: The hubcaps are the same color of your Cozmo. My Cozmo is black to gray, but the one from the creator shows a white Cozmo.
    Logan Bovan - Antwoord
  3. Anki Cozmo Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the 7.5 mm screw in the middle of each of the four red wheels using a JIS #1 screwdriver.
  4. Anki Cozmo Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the red hubcaps from each of the four wheels using your hands and fingers to pull them off.
  5. Anki Cozmo Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the 5.5 mm screw on the right side of the front gold bumper using a JIS #1 screwdriver.
  6. Anki Cozmo Battery Replacement: stap 6, afbeelding 1 van 2 Anki Cozmo Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove the 5.5 mm screw on the left side of the front gold bumper using a JIS #1 screwdriver.
  7. Anki Cozmo Battery Replacement: stap 7, afbeelding 1 van 2 Anki Cozmo Battery Replacement: stap 7, afbeelding 2 van 2
    • Remove the front gold bumper using your hands and fingers to pull it off.
  8. Anki Cozmo Battery Replacement: stap 8, afbeelding 1 van 2 Anki Cozmo Battery Replacement: stap 8, afbeelding 2 van 2
    • Remove the two 5.5 mm screws that lay deep on the right side of the gold body using a JIS #0 screwdriver.
    • One screw is towards the front wheel and one screw is towards the back wheel.
  9. Anki Cozmo Battery Replacement: stap 9, afbeelding 1 van 2 Anki Cozmo Battery Replacement: stap 9, afbeelding 2 van 2
    • Pry off the two white arms from the right side of the body and the two white arms from the left side of the body using two metal spudgers.
    • Pry off the arms by digging the tips of each spudger in between the arm and the body and pushing up away from the body.
    • The short arm on the right side of the body has a long white spring attached to it that runs through the center of the body.
    Steps 9 and 10 contain errors that will lead to broken parts of the robot.
    The upper arms (thin) must be pry off on both sides with metal spudgers. Then remove the white axis that connects them (what is called a spring here).
    And then you need to manually rotate the lower arms to the upper position (while slightly pulling them) until the latches are aligned with the corresponding slots in the case and the arms separate from the body. No force required.
    If you remove them with metal spudgers, you will leave marks on the case and break one or more of the latches.
    Nifty - Antwoord
    YES this is the good method to avoid broken arm :
    Madcat -
  10. Anki Cozmo Battery Replacement: stap 10, afbeelding 1 van 3 Anki Cozmo Battery Replacement: stap 10, afbeelding 2 van 3 Anki Cozmo Battery Replacement: stap 10, afbeelding 3 van 3
    • Remove the long white spring that is attached to the right short arm from the center of the body using your hands and fingers to pull it out.
    Nifty - Antwoord
  11. Anki Cozmo Battery Replacement: stap 11, afbeelding 1 van 2 Anki Cozmo Battery Replacement: stap 11, afbeelding 2 van 2
    • Pop off the two red square fascia from both sides of the white head using the metal spudger to pop them off.
  12. Anki Cozmo Battery Replacement: stap 12, afbeelding 1 van 1
    • Remove the two 5.5 mm screws from the right side of the white head using a JIS #0 screwdriver.
  13. Anki Cozmo Battery Replacement: stap 13, afbeelding 1 van 2 Anki Cozmo Battery Replacement: stap 13, afbeelding 2 van 2
    • Remove the right side of the white head using your hands and fingers to pull it off.
    • Do not unscrew or remove the two screws or the two white springs from the left side of the white head.
  14. Anki Cozmo Battery Replacement: stap 14, afbeelding 1 van 1
    • Pop out the black cover screen from the left side of the head using your hands and fingers to pull it out.
  15. Anki Cozmo Battery Replacement: stap 15, afbeelding 1 van 1
    • Remove the left side of the white head, along with the two short white springs that are attached to it, using your hands and fingers to pull them off.
  16. Anki Cozmo Battery Replacement: stap 16, afbeelding 1 van 2 Anki Cozmo Battery Replacement: stap 16, afbeelding 2 van 2
    • Unplug the black LED camera screen and the white and gold speaker from the small white plug in the center of the body using your hands and fingers to pull it off.
    • The camera and the speaker are attached to each other. They are removed in the same step.
  17. Anki Cozmo Battery Replacement, Battery: stap 17, afbeelding 1 van 1
    • Remove the two 5.5 mm screws from the red trim that was behind the white head using a JIS #1 screwdriver.
  18. Anki Cozmo Battery Replacement: stap 18, afbeelding 1 van 1
    • Remove the red trim that was behind the white head using your hands and fingers to pull it off.
  19. Anki Cozmo Battery Replacement: stap 19, afbeelding 1 van 1
    • Pop off the white and gold back trim that is connected to the LED panel using your hands and fingers to pull it off.
    • Do not unplug and remove the white and gold back trim. Leave the white and gold back trim hanging.
  20. Anki Cozmo Battery Replacement: stap 20, afbeelding 1 van 1
    • Remove the 7.5 mm screw from the gold bar in the center of the body using a JIS #1 screwdriver.
  21. Anki Cozmo Battery Replacement: stap 21, afbeelding 1 van 3 Anki Cozmo Battery Replacement: stap 21, afbeelding 2 van 3 Anki Cozmo Battery Replacement: stap 21, afbeelding 3 van 3
    • Pry apart the two halves of the gold body using your hands and fingers to pull them apart from each other.
  22. Anki Cozmo Battery Replacement: stap 22, afbeelding 1 van 3 Anki Cozmo Battery Replacement: stap 22, afbeelding 2 van 3 Anki Cozmo Battery Replacement: stap 22, afbeelding 3 van 3
    • Unplug and remove the silver battery from the bottom of the charging panel using your hands and fingers to pull it out.
    • Keep track of where the red and black wires get plugged into for reassembly.
    The battery is soldered into place, not plugged in. Perhaps this author confused this with Step 17 where they unnecessarily desoldered the speaker?
    Scott - Antwoord
    Max is a 750mAh akku after soldering old and new red and black cable.
    Attention: to power on you need to put cozmo to usb basestation. All 3 green led then working.
    (Or let us know to have a startup hint without prop. base) ;)
    Marc US - Antwoord
Conclusie
15 andere personen hebben deze handleiding voltooid.
Marisa Gay
702 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021 Lid van UMass Dartmouth, Team 4-8, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G8
3 Leden
7 handleidingen geschreven
14 opmerkingen
To detach the battery, don’t forget to remove the solder from the two points where the battery connects. (For Cozmo Collectors edition w/ press-able backpack button)
Kaptyn - Antwoord
The soldering steps are wrong. Don't desolder the speaker, but do desolder the battery.
Scott - Antwoord
Step 9 should be operated while the arm is at his maximum height.
Eric Hueber - Antwoord
Yes, excellent tip!
ticom3 -
Step 9 is the hardest from far ! And you'll easily get hurt by your tools. Moreover, reassembling cozmo will certainly deteriorate it. You should operate the big part of the arm (the lower) while the arm is at his maximum height. To do so, disassemble the white part of the fork by prying it down. Then remove the 2 screws of the upper arms, and remove these arms. Eventually, the big arm is easy to remove (or to reassemble).
Is it necessary to disconnect the screen? I am having trouble getting the little white connector pulled off and am wondering if I can just leave it connected
Alina - Antwoord
Its possible to carefully allow it to hang also.
Steve Hoffland -
This guide doesn't even mention soldering. Is it possible to replace the battery without soldering?
Bobo - Antwoord
no its not posseboul
sorry for the bad english
Johan Schütz -
I’m pretty sure I messed mine up. It turns on and everything is good after the battery replacement. But, now when I put it on the charger, the charger and the robot continuously flash and I don’t think it is charging. I may have messed something up on the soldering. Anyone have these symptoms after replacing the battery?
By the way, these instructions for disassembling and reassembling with the notes are spot on.
Noel Baggett - Antwoord
If battery is soldered on correctly should the Cozmo be able to power on before being reassembled?
Jared Katz - Antwoord
Hum, the arm may take a wrong "zero" position in memory at startup, but it's not sure. This is a good question. If you make the test, give us a feedback please. Merry Christmas !
Madcat - Antwoord
You do not need JIS screwdrivers. I have used Phillips head screwdrivers on Cozmo before. Also, for step 8, (at least for non button Cozmo’s) be careful. The non button’s back screws will strip more easily.
Thallium - Antwoord
I cut the cables of the old battery and attached a 620mah Battery Type 503040, 3,7Volt, Bye soldering. The 503040 is almost to big to fit in. You have to compress/bend the contacts one the Battery to fit but worked well.
Anton Späth - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 13
Afgelopen 7 dagen: 103
Afgelopen 30 dagen: 495
Altijd: 21,131
