Ga door naar hoofdinhoud
Amazon Kindle 8 Battery Replacement
Wat je nodig hebt
    1. Amazon Kindle 8 Battery Replacement, Front Cover: stap 1, afbeelding 1 van 2 Amazon Kindle 8 Battery Replacement, Front Cover: stap 1, afbeelding 2 van 2
      • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
      • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
      • Keep even pressure to avoid any cracks.
      • Lift front cover once all clips are disengaged.
      • Lift the front cover gently so that it is not cracked.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Kindle 8 Battery Replacement: stap 2, afbeelding 1 van 2 Amazon Kindle 8 Battery Replacement: stap 2, afbeelding 2 van 2
      • Insert the spudger between the inner front cover and the screen.
      • Gently work your way around to loosen the inner front cover.
      • Carefully lift the inner front cover from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Amazon Kindle 8 Battery Replacement, Motherboard: stap 3, afbeelding 1 van 2 Amazon Kindle 8 Battery Replacement, Motherboard: stap 3, afbeelding 2 van 2
      • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Kindle 8 Battery Replacement: stap 4, afbeelding 1 van 2 Amazon Kindle 8 Battery Replacement: stap 4, afbeelding 2 van 2
      • Lift the screen and motherboard from the back cover.
      Vraag FixBot
      Voeg opmerking toe
    1. Amazon Kindle 8 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
      • Pinch the clips on the battery and disconnect the battery connector from its socket.
      Vraag FixBot
      Voeg opmerking toe
    2. Amazon Kindle 8 Battery Replacement: stap 6, afbeelding 1 van 1
      • Insert the halberd spudger between the motherboard and battery.
      • Take care not to bend, twist, or puncture the battery.
      • Slowly move the spudger around the battery and pry it off.
      • The battery is glued in place, so don't be afraid to use some moderate force.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Luke
444 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 64
Afgelopen 30 dagen: 307
Altijd: 6,105
