Amazon Fire HD 10 USB Charging Port Replacement
Inleiding
This video guide will show you how to solder and fix a broken charging USB port.
Wat je nodig hebt
Gereedschap
Toon meer…
Video-instructies
To reassemble your device, follow these instructions in reverse order. Be sure connection pins (in the center of the pad) have enough solder to reattach the the replacement micro-usb.
12 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Can you use usb replacement parts for fire hd 6, 7 and 8.9 for the fire hd 10?
custmadehancraf - Antwoord
Some English narration instead of the annoying music would be useful. Unsoldering looked rather magical, what was the heat source? Hot air gun under the board? You’re daubing on cleaner and flux, I guess, no idea what’s what. Paste solder?
Alan Corey - Antwoord
Is there a way to know if it's the battery or the charging port
Tech Reviews - Antwoord
