Ga door naar hoofdinhoud
Acer Chromebook R11 C738T-C44Z Wireless Card Replacement
Connie Hernandez
Connie Hernandez en 2 andere bijdragers
Voor het laatst geüpdatet op December 30, 2021
20 - 40 minuten
Gemiddeld
Actiemomenten
Heeft betere plaatjes nodig
Behoeft meer afbeeldingen
Follow this guide if you need to replace the Wi-Fi card of your Acer Chromebook R11 C738T-C44Z. If your device is having trouble connecting to any networks or very slow speeds, it is most likely time to replace it. This replacement is needed if you cannot connect to networks wirelessly.
Before you begin, make sure to shut down your laptop and drain any residual power.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: stap 1, afbeelding 1 van 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: stap 1, afbeelding 2 van 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: stap 2, afbeelding 1 van 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: stap 2, afbeelding 2 van 2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  3. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  4. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: stap 4, afbeelding 1 van 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: stap 4, afbeelding 2 van 2
    • Carefully slide the wireless card out of its socket from the motherboard.
Conclusie
Connie Hernandez
517 Reputatie
4 handleidingen geschreven
Gateway, Team 1-4, Saknee Fall 2021 Lid van Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 393
