Ga door naar hoofdinhoud
Acer Aspire V5-591G-75KE Disassembly
Tasier Hagler
Tasier Hagler en 4 andere bijdragers
Voor het laatst geüpdatet op May 16, 2024
5 - 10 minuten
Gemiddeld
Betere introductie
Wat je nodig hebt
Gereedschap
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: stap 1, afbeelding 1 van 3 Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: stap 1, afbeelding 2 van 3 Acer Aspire V5-591G-75KE Disassembly, Acer Aspire V5-591G-75KE Disassembly: stap 1, afbeelding 3 van 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Disassembly: stap 2, afbeelding 1 van 2 Acer Aspire V5-591G-75KE Disassembly: stap 2, afbeelding 2 van 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Disassembly: stap 3, afbeelding 1 van 2 Acer Aspire V5-591G-75KE Disassembly: stap 3, afbeelding 2 van 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Disassembly: stap 4, afbeelding 1 van 3 Acer Aspire V5-591G-75KE Disassembly: stap 4, afbeelding 2 van 3 Acer Aspire V5-591G-75KE Disassembly: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tasier Hagler
428 Reputatie
4 handleidingen geschreven
UW Tacoma, Team S3-G5, Liner Fall 2017 Lid van UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Leden
18 handleidingen geschreven
Één opmerking
Buna ziua , Se poate înlocui procesorul cu unul m-ai performant (Gen I9,I7 -14700 ,etc.) ? Care ar fi acesta ?Mulțumesc !
Lucian Icu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 50
Altijd: 4,408
