Ga door naar hoofdinhoud
Acer Aspire One D255E Screen Replacement
Brian
Brian en een andere bijdrager
Voor het laatst geüpdatet op September 17, 2019
Geen schatting
Gemiddeld
Damaged screens are one of the most common issues that will occur with a computer. While most laptops require the complete disassembly of the computer to replace the screen, the Acer Aspire One D255E requires significantly less work. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
Wat je nodig hebt
Gereedschap
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Acer Aspire One D255E Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Acer Aspire One D255E Screen Replacement, Screen: stap 1, afbeelding 2 van 2
    • Using a spudger remove the two screw covers on the front of the computer.
  2. Acer Aspire One D255E Screen Replacement: stap 2, afbeelding 1 van 2 Acer Aspire One D255E Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 1.2 mm Phillips #1 screws that were located under the screw covers.
  3. Acer Aspire One D255E Screen Replacement: stap 3, afbeelding 1 van 1
    • Using a spudger for assistance remove the front panel of the screen.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Screen Replacement: stap 4, afbeelding 1 van 3 Acer Aspire One D255E Screen Replacement: stap 4, afbeelding 2 van 3 Acer Aspire One D255E Screen Replacement: stap 4, afbeelding 3 van 3
    • Remove the eight 1.2 mm Phillips #1 screws holding on the screen.
    • There are wires connected to the screen unit. Make sure you do not attempt to pull off the screen just yet!
  5. Acer Aspire One D255E Screen Replacement: stap 5, afbeelding 1 van 1
    • Carefully remove the display ribbon cable from the connector.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Brian
1.302 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 16-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S16G8
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 2,291
