ASUS Q400A-BHI7N03 Power Jack Replacement
Inleiding
Ga naar stap 1It is a common issue among ASUS Q400A laptops to refrain from charging. Among battery and charger issues, it is likely that the power jack isn't operating correctly. The following is a guide explaining how to gain access to the power jack for replacement.
Wat je nodig hebt
Flip laptop over with the battery facing toward you.
Slide both tabs with the lock/unlock symbol, near the battery on the right of the notebook, to the unlock position.
Grab the top edge of the battery & lift upward to relieve the battery from its slot.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Unscrew the two black 8mm Phillips #0 screws.
Firmly grasp each antenna head with a pair of blunt tweezers and detach it by lifting up straight.
Één andere persoon heeft deze handleiding voltooid.
