Nintendo Switch Pro Controller Joystick Caps Replacement
Inleiding
Ga naar stap 1After using the Nintendo Switch Pro Controller (Model HAC-001), it is common that the joystick cap becomes cracked or broken. Though the caps are not integral to the functionality of the controller, the caps provide comfort and ease of use of the joysticks. This guide helps with only the replacement of the joystick caps, not the joystick itself.
Wat je nodig hebt
Flip the controller over so the model stickers face the ceiling.
Use a JIS #00 screwdriver to remove the two black 8.4 mm screws that secure the handles, located at the ends of the handles.
Carefully remove the handle covers by pulling them away from the main body.
Use a JIS #00 screwdriver to remove the four silver 6.8 mm screws that secure the clear back plastic cover.
Carefully pry away the clear plastic cover using your fingernail.
Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
Use a Phillips #1 screwdriver to remove the five 5 mm screws from the back of the controller.
The two case screws above the handgrips and the single case screw below the battery bay have a shallow seat. These three screws can be easily removed.
The two case screws adjacent to the ZR and ZL shoulder buttons have a deep seat. Use an extension or a Phillips screwdriver with a longer shaft to reach these screws.
Use the tip of an opening pick to open the black flap of the ZIF connector by pushing it upwards.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use your fingers or a pair of blunt nose tweezers to disconnect the interconnect cable from its connector.
With light force pull the two joystick caps off of the controller.
27 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Where can I get the replacement caps?
do you know where to find a replacement cap? If so can you give me link, thanks!
You really don't need to disconnect the ZIF to replace the caps. It might make things a tiny bit easier, but is best not to mess with it AT ALL if you're only replacing the caps. As messing it up, or not connecting it properly when you're putting it back together can lead to ALL your face buttons and D-pad not working.
