Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Camry XV40 werd geïntroduceerd op de North American International Auto Show van 2006, samen met een hybride uitvoering, en kwam in maart 2006 op de markt voor het modeljaar 2007.
Air-conditioning temperature control issue
The automatic climate control system does not function properly upon starting the vehicle. The AC fails to blow cold air at standard temperature settings (e.g., 22°C / 72°F) and will only begin cooling if the thermostat is manually forced to its absolute lowest setting ("MAX AC" / "LO"). Once the cabin cools down under this maximum setting, the temperature can then be adjusted back up to a preferred comfortable level, and it will hold that temperature normally for the remainder of the drive. This issue occurs every time the car is started.
Is dit een goede vraag?
1 Opmerking
This can be an expensive, time consuming repair performed by repair shops or dealer, or by yourself if you are comfortable using service manuals and can diagnose, troubleshoot and use tools including a multimeter. You can always get an estimated cost from several repair shops and dealer otherwise you might consider it more expensive than its worth and accept this as a working solution on an aging vehicle.
door
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
Hi @vajirampap51825
Get the vehicle's OBDII port scanned with a scantool and check if any DTC codes pertaining to the Air conditioning system have been stored by the A/C amplifier module. The code will tell you what the problem might be.
You could always use the A/C self diagnosis procedure and check what that shows as well.
Was dit antwoord nuttig?
Score 1
I am guessing that the max cool position bypasses the sensor. Why it starts working normally after that ??
You would likely do better on toyotanation.com
Voeg je antwoord toe
vajiram papanaidu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 112
