Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Uitgebracht in november 1998, te herkennen aan modelnummer HKT-3020.
What is going on here?
Hi, I recently install the retro gem for my Dreamcast and when I boot the system it doesn't show the boot animation for the system only when its completed I went to debug menu and have hearts on all my installs as well as updated the firmware. I tried this on two TVs and it does the same thing. I have a Gamecube with a plug-in mini-HD to HD and it does something similar I used the same cable from that.
Is dit een goede vraag?
8 opmerkingen
Hi!
Is it possible to upload some pictures regarding the issue you are facing?
Voeg afbeeldingen toe aan een bestaande vraag
Thank you.
door
Can I upload video? pictures won't help
door
Yes you can!
Using Media
Thank you
door
Hi, I upload the videos in the first video it's the gamecube with the hdmi plug-in, the second one is the gamecube with S-video, and the third one is the dreamcast with the mini-HD to HD. I used the mini-HD to HD from the plug-in I couldn't get the av footage for the dreamcast cause I think I messed something up ....again, but it does the same thing as the gamecube plug-in. I hope its just the mini-HD to HD cable that's causing this. It's the basic edition of pixelfx mod
door
Okay, replacing the cable you can try indeed. It does not really look like a hardware issue in the first 2 pictures. More firmware related. Which firmware has been installed? Thanks!
door
3 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
@dan0 Hi, I went on the retro gem discord and I was told that the delay in video is normal because the retro gem is booting.
Was dit antwoord nuttig?
3 opmerkingen:
Alright. Then it is normal behaviour. Thanks for sharing!
door
Sorry for the delay thank you
door
No problem at all! Have a great day :)!
door
Voeg je antwoord toe
Christopher D zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 37
Altijd: 217
