Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor uw Toshiba-tv.
Old king Horizontal line problem
Afbeelding
Secret cards name is lnv55L96c made by Samsung.
Afbeelding
there is a secret card under metal sheaild***
Toshiba 55sv685d
What ist the problem? I love this tv. Can you help me please?
bDys23xvRHKQVJfZ.full (4000×3000) https://share.google/YsSsvDXFM1pmCy4sN
Update (05/25/26)
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Afbeelding
Is dit een goede vraag?
2 opmerkingen
@fatihemre that will depend what it looks like. Horizontal lines are usually caused by issues with the panel. We will see what your TV shows you. Post a picture of that with your question. That way we can see what you see Voeg afbeeldingen toe aan een bestaande vraag
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@fatihemre those lines can be caused by the main board as well as bad LVDS cables. Worst case is a bad panel. I would remove the back cover and check the flat ribbon cables for any tear and corrosion. You can always clean the ends of the cables with a pencil eraser. If that does not help, you could try a main board, provided you can find one for a decent price. Once you have the back cover off post some good pictures of the boards and the interconnect cables etc. That way we can hopefully assist you with that further.
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
Where should I focus on?
door
@fatihemre the main board is the big green one. The smaller green board is your T-Con board and the large brown one is the power board. For now I would focus on the large green board
door
@oldturkey03 info: secret cards name is INV55L96C, made by Samsung. I dont know what its job.
door
@fatihemre that is your LED controller. It controls the LED baklight strips.
door
info: when tv is cold first start there are no horizontal lines, after 2 minutes I hear A low, high-pitched sound and horizontal lines appear.
door
Voeg je antwoord toe
Fatih81 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 171
