Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie- en probleemoplossingsinformatie voor het FixHub Power Series | Mobiele Soldeerstation, de combinatie van het mobiele soldeerstation en de slimme soldeerbout. Gelanceerd in oktober 2024.
Touch-Safe indicator blinking blue.
My screen on my power station is not functioning, and I was able to still use my soldering iron using the touch-safe indicator for power on and heat up indication. During a recent job my soldering iron stopped heating up and started steady blinking blue.
Before the heat up blink was more of a slow pulse as it started turning orange. My firmware on both the power station and soldering iron is up to date and matching.
I could not find what the steady blue blink represents in any of the documentation. I'm still waiting for parts to become available to replace the screen.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Hi, @ofglamis I gotchu.
Good news! I think I know the cause to these problems.
The power bank needs a replacement screen, and iFixit sells a replacement display. The iron itself needs a new main board. I have the part links here and here, if you need a shortcut.
While wating for the new screen, you can use the web console. The guide included in the link will teach you how to do so.
Replace a damaged or malfunctioning display for your FixHub Power Station. Afbeelding
Product
FixHub Power Station Replacement Display
$19.95
Replace a corroded or malfunctioning main board for your FixHub Soldering Iron. Afbeelding
Product
FixHub Soldering Iron Replacement Main Board
$34.95
Was dit antwoord nuttig?
1 Opmerking:
Thanks for the input, I've been waiting for the screen to comeback into stock for the last few months. It looks like main board for the soldering iron is in the same boat. I guess I'll need to get a new travel soldering station until parts return to stock.
door Deel
Voeg je antwoord toe
ofGlamis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 50
Altijd: 142
