Ga door naar hoofdinhoud
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether push style, or ride-on.
1209 Vragen Bekijk alle
Vraag afgerond
Are all pulleys on the mower deck on the same level/plane?
keep shredding mower deck belts, installed new idler pulleys but the ones on the left are slightly higher (about 3/4inch) than the other idler pulley.
Is dit een goede vraag?
2 opmerkingen
Thank you for responding with your suggestions.
I aligned the pulleys so there is only a 1/4 difference, bought a new belt,
mower working great.
door
Thank you for accepting my answer.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
tom, the pulleys should be aligned so that the belt runs level. If one of the pulley's is higher, your belt will shred since it is not running level. Get the instructions from here. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
The left blade pulley, the left large metal idler and the left small plastic idler are 1/4inch higher than the right plastic idler, center blade pulley and the right blade pulley. It looks like it has always been that way because there is no signs of any pulley suppports deterioating or having been changerd in height.
door
Is it wide enough to allow the belt to continue to run straight. Did you check the manual to make sure it is all the way it is supposed to be.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,210
