Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Meta Quest 3S mixed reality-headset werd uitgebracht op 15 oktober 2024 en is het jongere en kleinere broertje van de Meta Quest 3.
How do I fix meta quest 3s controller button?
Afbeelding
I got some wd40 to help with a stick drift issue, but some of the wd40 got onto one of the controller buttons, and now it's not responding to my input. I'm still able to press the button, but it doesn't make the same sound compared to the rest of the buttons on my controllers when i press them. It's been quiet after i heard a crunching sound when i pressed it after the wd40 i put on the joysticks was able to dry.
What do i do? Am i able to fix it, or do i need a new controller all together?
Is dit een goede vraag?
1 Opmerking
my y buttin just stoped woking and i did not do angoning it looks fine on the outside i dont know what to do
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi!
Sound like the contact of the button is damaged. Depending on which button it is, I would replace it completely and see what happens.
Otherwise replacing the controller is a option, but let's check what we can do first.
Can you also sent us some pictures regarding the button? Thanks!
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
I edited my post to show a picture of the controller. It's the X button that isn't working. Nothing looks broken on the outside from what i can see.
How do i replace the contact of the button? Do i need to open up my controller to access the button contact?
door
Hi!
Yes, you need to open it up and check the button and rubber, clean it both with isopropyl alcohol. And please share a picture regarding the button inside the controller. Inside the controller is where you need to clean unfortunately.
door
I'll try to get my hands on some isopropyl alcohol soon. Do i need a certain tool/method to open up the controller? I don't wanna break the controller by accident.
door
Alright, great!
Yes, you need a Torx (T)5 screw driver, tweezers and a pry tool, like a spudger.
You can find everything in here: https://www.youtube.com/watch?v=EYa9UeDJ... Please follow this one to safely open your controller.
Please let us know how it goes!
door
Voeg je antwoord toe
Skitzo Phrenic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 117
Altijd: 917
