Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Asus K55VD beschikt over een 3e generatie Intel® Core i5-processor en NVIDIA® GeForce 600M-graphics met Microsoft DirectX 11. De behuizing is gemaakt van aluminium met een afwerking met textuur aan de bovenzijde, en is verkrijgbaar in diverse kleuren.
Unknown USB descriptor request failed
I just recently installed a SSD in my laptop and there's this bugging me all of a sudden. The USB port near the audio jack has this problem and it wont let me plug in USB devices let it be Hard drives or Printer cables. How do I fix this? :<
[Windows has stopped this device because it has reported problems. (Code 43)]
Is dit een goede vraag?
4 opmerkingen
door Deel
@stormchase86098
Just clarifying when you say "....it wont let me plug in USB devices....", do you mean that they won't physically plug in (damaged connector?) or that USB devices can be plugged in OK but just don't work?
door Deel
@jayeff It just wont work. It detects that theres a device plugged in but it will say "Unknown USB descriptor request failed". Sorry for my bad grammar and "unpunctual" replies
door Deel
@stormchase86098 Did it work before you installed the SSD? Bad data lines either on the port or on the motherboard can be causing this.
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Het nuttigste antwoord
@stormchase86098 lets rule out software first. Start by updating or reinstalling the latest USB drivers. Delete the current one and then reinstall the new drivers in Device Manager. If that does not resolve it , it is possible that this is a power supply issue to the USB port. For that we would need to see your motherboard and need to know the exact motherboard number.
Voeg afbeeldingen toe aan een bestaande vraag.
Was dit antwoord nuttig?
Score 1
The “Unknown USB Device (Device Descriptor Request Failed) – Code 43” error usually appears due to driver corruption, power issues, or a damaged USB port. Since you recently installed an SSD, first check if any internal cables were disturbed. In Windows, open Device Manager → Universal Serial Bus controllers → uninstall the “Unknown USB Device,” then restart your laptop to reinstall drivers automatically. Also update chipset and USB drivers from your laptop manufacturer’s website. Try disabling USB selective suspend in Power Options. If only one port (near the audio jack) fails, it may be physically damaged and require hardware repair or port replacement.
Voeg je antwoord toe
Stormchaser JanJames zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 34
Altijd: 287
