Ga door naar hoofdinhoud
De derde revisie van de klassieke Xbox Draadloze Controller werd uitgebracht in november 2020, gebundeld met de Xbox Series X en Series S. Deze controller is achterwaarts compatibel met eerdere Xbox One-consoles en pc's.
New TMR Sticks Not Working
I am nee to soldering and know the basics. I replaced both joysticks with new TMR sticks with new Xbox joystick soldering tool. Replacement and soldering went well. But when I go to check controller with Xbox app, it connects but I can't move or use any part of controller. Any thoughts?
Is dit een goede vraag?
2 opmerkingen:
Hi!
Did you tried it here as well > https://hardwaretester.com/gamepad
What is working and what isn't?
door
Nothing works other than the controller turning on and connecting to xbox. I'd post a video if I could
door
Voeg een opmerking toe
1 Antwoord
Hi!
Thanks for your comment!
Perhaps traces are damaged or the board went to hot.
Please check if everything is connected as it should and also for damaged traces.
I’m afraid your motherboard did die or isn’t connected properly.
Can you check this? Thanks!
Was dit antwoord nuttig?
2 opmerkingen:
I will have to check for this a little later, but that may be the case. I'm wondering if I may have had too much heat when desoldering the original analog sticks. Thank you
door
That is possible yes... In this case you most likely want to replace the motherboard, but this isn't cheap...
door
Voeg je antwoord toe
kmuetz zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 31
Altijd: 206
