Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
A1708/EMC 3164 — Uitgebracht in juni 2017; deze instapmodel MacBook Pro behoudt zijn traditionele functietoetsen (in tegenstelling tot de OLED Touch Bar).
Problems with battery cable!
Hi I accidentally unclipped the sister ribbon and had a vey hard time connecting it. I had the same issues as you are having above. I actually took it to a repair shop and she connected the ribbon but I am still having the same issues. It doesn't show the battery - and it won't stay charged and the fan stays on. I am a little confused on what to do next ... I am not very tech savvy so I really do need to instruction - thanks Kristina
Is dit een goede vraag?
1 Opmerking:
@kristinam66215 is this different then the one on here What if I broke the clip on the sister ribbon connector ? If not, then stay with the original question and delete this one.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
From your other note it sounds like the Zero Insertion Force (ZIF) cable connectors latch was lost. Review the steps 11& 12 in this guide MacBook Pro 13" Function Keys 2017 Battery Replacementto verify that they are both present. The do need to be present and set as they compress the cable to create the needed connection.
Was dit antwoord nuttig?
2 opmerkingen:
I am for sure that the cable connector latch is broken off... What will I need to do now? Is there a way to order a new latch? It's so tiny.... or do I need to order something else? Thank you
door Deel
@kristinam66215 - the latch it's self is not available as a spare, but! The connector is, and you can carefully snap it out to the. Put into your logic board connector to fix things. Here's the connector Macbook A1708 A2338 A2159 A2289 Battery Data FPC Connector Socket 10Pin on Motherboard
door Deel
Voeg je antwoord toe
Kristina M zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 218
