Left joystick is spinning
Hi
I have a 8bitdo Ultimate controller and recently the left joystick has started spinning, which is really annoying.
What can I do to fix it?
Is dit een goede vraag?
Hi
Hi!
Okay, either the joystick broke off and causing the thumbstick to get loose. Or it just went lose (hopefully this is it).
The only thing you can do is to open it up and check the joystick!
Guide: Disassembling 8BitDo Ultimate Bluetooth Controller - iFixit Repair Guide
If the joystick broke off, you should replace it. This requires soldering unfortunately...
Please let us know how it goes!
Was dit antwoord nuttig?
If I need to make the bigger repair and replace the joystick part (a different mechanical malfunction), where would I look for replacement parts?
Aliexpress, Ebay or Amazon are your best bet. Also: you have most of the time, 2 different joysticks. A smaller one and a bigger one. Sometimes they are kinda universal. So you need to check first what you need.
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 30
Afgelopen 30 dagen: 79
Altijd: 757
