Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de vijfde generatie Sony PlayStation 5 DualSense-controller. Geïdentificeerd door modelnummer CFI-ZCT1W en moederbordmodel BDM-050.
Replacing haptic feedback rumble motors?
I've noticed recently after playing a lot of the f1 game, my haptic feedback is just suddenly extremely weak compared to what it used to be. I've tried pretty much everything I think and nothing works, tried enabling the speaker in my sound settings but my controller doesn't even appear in there. I downloaded dualsense x and tested the right side and left side rumble motors by themselves and the right side is significantly weaker. Wanted to know if replacing the rumble motors would be possible on the V5 since I don't already see any guides here and if so is it just the rumble motors that need to be replaced or anything also involving the triggers?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi!
The process is nearly the same as V2, V1 ect ect.
So you should be able to use the same guide that is created for the V2 or V1.
How is the haptic feedback? Still good? If yes, then you do not need to replace them, but just the rumble motor it self.
Guide: DualSense Controller v2 Vibration Motor Replacement - iFixit Repair Guide
If the haptic feedback buttons are back or got a lot weaker, then I advise to replace them as well.
Guide: DualSense Controller v2 Adaptive Trigger Replacement - iFixit Repair Guide
So far it does look like you just need to replace the rumble motors.
Please let us know if you have any questions!
DualSense Controller v2 Adaptive Triggers Afbeelding
Handleiding
DualSense Controller v2 Adaptive Trigger-vervanging
Moeilijkheid:
Gemiddeld
30 minutes - 1 hour
DualSense Controller v2 Trilmotoren Afbeelding
Handleiding
Vervanging van de trilmotor van de DualSense Controller v2
Moeilijkheid:
Moeilijk
1 - 2 hours
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Not muting your mic can override your haptics settings and set them to low or off make sure the button at the bottom is lit orange.
door
Voeg je antwoord toe
brending zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 55
Altijd: 829
