Ga door naar hoofdinhoud
De derde revisie van de klassieke Xbox Draadloze Controller werd uitgebracht in november 2020, gebundeld met de Xbox Series X en Series S. Deze controller is achterwaarts compatibel met eerdere Xbox One-consoles en pc's.
How can I remove stuck pin?
Afbeelding
Afbeelding
Pin is mushroom at the top, meaning no grip, but at the bottom it has grip. I used a desoldering gun and wick still didn’t work, so I got a hot air station. Still doesn’t work. Temperature I used was 300-400°C for 15 seconds or more, but it depends. Solder is lead-free.
Is dit een goede vraag?
4 opmerkingen:
Hi!
Are you able to upload some photos? This will make it easier for us to come with an answer! Thanks!
door
Mybad updated picture uploaded
door
@dan0, for equipment, I have an atten heating station, a Hako desoldering gun, and a soldering iron Hako 8888DX.
door
Thanks! Do you have a hot air station? Would try that and then try with tweezers to get it out. Make sure you use flux first. It should come out.
door
Voeg een opmerking toe
1 Antwoord
I would add flux and then solder, heat, and try to pull with tweezers. Might need to increase the heat as well. Hope this helps.
Was dit antwoord nuttig?
2 opmerkingen:
I tried using that method to increase the temperature, but nothing happened. Is there a way I can demonstrate it to you on FaceTime?
door
I’m thinking about getting a another daughter board but at the same time what if that issue come up again
door
Voeg je antwoord toe
randy 098 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 210
