Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor C/K-pick-ups die door General Motors onder het merk GMC werden verkocht, inclusief de GMC Sierra.
How can I fix or replace dash gauges?
Update (09/06/25)
@oldturkey03 Yeah it's a 94 GMC Sierra k1500 .
Seems oil pressure gauge(which I changed few years ago/failing to start) started too be erratic, year later or so the temp gauge goes rt too hot when running a few seconds, (pump replaced years ago, coolant good and no overheat). I changed sensors/wires (two), cleaned MaP sensor, checked grounds, found one broken but had no effect when connected. Didn't replace thermostat yet but have it, my guru says it's likely gauges going, there's motors in them that die off, short of tearing things apart thus breaking clips etc, what else is good or how to take out the cluster and replace it or gauges etc on the very cheap low expense end.
Seems The air/fuel mixture due pcm being told it's running hot (which happened years ago w broker fan belt) causes choking when stopped like it's timing is off-rumbling sensation. Worried about damaging worse then already may have driving
Is dit een goede vraag?
1 Opmerking
@glentrs what exact year and model is your Pickup?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@glentrs I'd remove the instrument cluster and take a look at the back of it. See if there are burned/corroded traces etc. To remove the cluster use the service manual page 262. You can now download it from this page 1988-1998 GMC Pickup under the Documents Tab. For a more in-depth information about your cluster, look at the 1994 CK Truck SM that you can get on the same page. Check page 1280 in that manual.
Once you have the cluster out turn it over and take some pictures. Let's see if we can find anything odd looking on it.
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
1 Opmerking:
Ok OT ! I need a few days to get car running good so I won't be without. THANKS for the leads !
door
Voeg je antwoord toe
Glentrs zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 26
Altijd: 304
